Ροδοπουλος Δημοσιεύτηκε Δεκέμβριος 17 , 2010 Συγγραφέας Share Δημοσιεύτηκε Δεκέμβριος 17 , 2010 Μαρτενσιτικη ζώνη!!! Link to comment Share on other sites More sharing options...
terry Δημοσιεύτηκε Δεκέμβριος 17 , 2010 Share Δημοσιεύτηκε Δεκέμβριος 17 , 2010 Λιγο αναλυτικοτερα??? Δλδ οι υπολοιποι χαλυβες δεν εχουν μαρτενσιτη?? Link to comment Share on other sites More sharing options...
Ροδοπουλος Δημοσιεύτηκε Δεκέμβριος 17 , 2010 Συγγραφέας Share Δημοσιεύτηκε Δεκέμβριος 17 , 2010 απο Tempcore? nope!!! Link to comment Share on other sites More sharing options...
Ροδοπουλος Δημοσιεύτηκε Δεκέμβριος 17 , 2010 Συγγραφέας Share Δημοσιεύτηκε Δεκέμβριος 17 , 2010 Corrosion of steel reinforcement due to atmospheric pollution Department of Materials Science and Engineering, School of Chemical Engineering, National Technical University of Athens, 9, Iroon Polytechniou St. GR-157 80 Zografou, Athens, Greece Abstract The aim of this study is to examine the performance of four different sets of reinforcing steel rebars, S220, S400, S500s Tempcore and S500s Vanadus, exposed to the Greek atmosphere, before their installation into the concrete. The performance against atmospheric corrosion of the aforementioned steel rebars was evaluated by means of microscopy techniques and corrosion rate measurements. In particular, we studied the influence of corrosion products of a set of reinforcement steels on the bond strength between concrete and steel bars, during the hydration process of cement. Furthermore, microscopy techniques and visual observation were used to identify the rust strains and the corrosion product morphology of steel reinforcements before their installation into the concrete. The experimental results shown that the steel type, which exhibits the higher resistance, as far as atmospheric corrosion concerns, was S220 reinforcing steel. In contrary, S500s Tempcore has the least corrosion resistance. The bond strength between concrete and the steel rebars was found to decrease with increasing weathering from 45 to 122 days, due to the morphology and to the thickness of the rust layers formed on steel surface, as observed by the ESEM. Microstructures and mechanical properties after heating of reinforcing 500 MPa class weldable steels produced by various processes (Tempcore, microalloyed with vanadium and work-hardened) θα το βάλω αύριο. Link to comment Share on other sites More sharing options...
Ροδοπουλος Δημοσιεύτηκε Δεκέμβριος 18 , 2010 Συγγραφέας Share Δημοσιεύτηκε Δεκέμβριος 18 , 2010 Λοιπόν απαντάω στον terry Αυτό που θα πρέπει να καταλάβουμε ειναι οτι οι χάλυβες τύπου tempcore έχουν ενα μαρτενσιτικο εξωτερικό περίβλημα το οποίο είναι αποτέλεσμα του tempcoring. Τώρα κρυσταλλικά και χημικά δεν μιλάμε για καθαρό μαρτενσιτη όπως πχ στα ανοξείδωτα, αλλα για κραμματικό. Βάζω δυο paper για διάβασμα. Τώρα οι εταιρείες λένε οτι έχει καλύτερη αντοχή στην διάβρωση όχι σε σχέση με τα παλία (εκτος S500s) αλλα σε σχέση με αλλα tempcore σε χαμηλότερη θερμοκρασία. http://rapidshare.com/files/437957788/batis.pdf http://rapidshare.com/files/437957851/tempering.pdf Link to comment Share on other sites More sharing options...
Ροδοπουλος Δημοσιεύτηκε Δεκέμβριος 18 , 2010 Συγγραφέας Share Δημοσιεύτηκε Δεκέμβριος 18 , 2010 Επειδή εαν δεν το δω, το ελέγξω, κλπ δεν το ξέρω καν. Δοκίμασα το PENETRON την επάλειξη σε πλάκα σκεπής και το προιόν είναι αστέρι. Το έβαλα προχθες και σήμερα έβρεχε παιρνω το υγρασιόμετρο και μετράω απο πάνω και απο κάτω. Απο πάνω έχω υγρασία 32% και απο κάτω 72%. Πηρα ένα κουβά 10 λιτρα του βγάζω τον πάτο και το κολλάω με σιλικόνη το γεμιζω νερό και μετράω στάθμη μέχρι τώρα απο 9 το πρωί δεν κατέβηκε καθόλου. Link to comment Share on other sites More sharing options...
terry Δημοσιεύτηκε Δεκέμβριος 18 , 2010 Share Δημοσιεύτηκε Δεκέμβριος 18 , 2010 Θα μελετησω αυτα που παραθεσατε.. Το penetron τι ειναι??? Εχω χασει κατι??? Υπαρχει λινκ?? Οσο για τον κουβα μπορει να κατεβει η σταθμη και λογω εξατμισης.. Link to comment Share on other sites More sharing options...
Ροδοπουλος Δημοσιεύτηκε Δεκέμβριος 18 , 2010 Συγγραφέας Share Δημοσιεύτηκε Δεκέμβριος 18 , 2010 http://www.penetron.gr/ στους 3 βαθμούς με συνεφιά πόσο να χάσει? Και δεν παίρνω και φήμη και με κερδίζει ο AlexisPap Το θετικό είναι οτι μπορεί να σταματήσει υγρασία και διαρροές σε ΦΟ υπογείου, θεμέλια, κλπ. Λοιπόν θα σωσουμε την Θεσαλοννίκη και Βολο. Νέες θεμελιώσεις, κλπ. Ξαναμέτρησα πριν απο λίγο (32 ώρες). Άδειασα τον κουβά και η υγρασία είναι πάλι 38%. Δεν είχα απώλεια νερού απο τον κουβά. Είχα χάσει 52 γραμ προφανώς απο εξάτμιση. Link to comment Share on other sites More sharing options...
Ροδοπουλος Δημοσιεύτηκε Δεκέμβριος 20 , 2010 Συγγραφέας Share Δημοσιεύτηκε Δεκέμβριος 20 , 2010 Αυτό με τα 11 MPa. Τα χλωριόντα είναι 0.23% κβ σκυροδέματος. Αυτό που βλέπετε είναι το επισκευασμένο πριν απο 3 χρόνια. Τα χλωριόντα μετρήθηκαν σε βάθος 120 χιλ και αποτελεί κλασσικό παράδειγμα οτι δεν είναι απο εξωτερική προσβολή αλλα απο άλατα που μπήκαν στο σκυρόδεμα ή υφάλμυρο νερό. Link to comment Share on other sites More sharing options...
Ροδοπουλος Δημοσιεύτηκε Δεκέμβριος 21 , 2010 Συγγραφέας Share Δημοσιεύτηκε Δεκέμβριος 21 , 2010 1. Κάντε ελεγχο για να βρείτε τα αίτια του προβλήματος. 2. Κάντε έλεγχο για να βρείτε την έκταση του προβλήματος 3. Αποφύγετε τα τοπικά μερεμέτια, απλά θα μετακινήσετε το πρόβλημα αλλού. Ο έλεγχος πρέπει να σας δώσει τα όρια της επισκευής. 4. Καθαρίστε διεξοδικά την όπλιση περιμετρικά. Εαν φοβάστε υποστυλώστε. 5. Κοιτάξτε για βελονισμούς. Σε ποσοστό πάνω απο 80% προέρχονται απο χλωριόντα. 6. Επειδή δεν είναι κοντά στην θάλασσα δεν σημαίνει οτι δεν έχει χλωριόντα. 7. Ο δείκτης ενανθράκωσης είναι δείκτης πεχα. Η πτώση του δεν οφείλετε μόνο στους ρύπους. 8. Εαν υπάρχουν χλωριόντα ή χημική προσβολή οι αναστολείς δεν σας παρέχουν προστασία εαν η προσβολή δεν καθαριστεί. 9. Μην βάζετε αναθρακουφάσματα εαν δεν ειστε σίγουροι οτι δεν υπάρχει ανοδική υγρασία. Επίσης καταλάβετε οτι μετα το ύφασμα δεν θα ξαναπάρετε ενδείξεις διάβρωσης. 10. Τα υφάσματα θα πρέπει να μπαίνουν με μικρά κενά 1-2 εκ για να επιτρέπουν διαπνοή. 11. Καθαρίστε και μετρήστε την εναπομένουσα διατομή. Εαν έχετε χάσει πάνω απο 5%, ξέρετε τι κάνετε.... 12. Αποφλοιώσεις σημαίνουν απώλεια συνάφειας. Για την επαναφορά κάντε χρήση κονιαμάτων με αντοχή κοντά στην αντοχή του σκυροδέματος. Αποφύγετε μεγάλα πάχη με ένα πέρασμα. Εαν το σκυρόδεμα σας είναι Β160 ή Β225 αποφύγετε κατηγορίες R3, R4. Κατασκευάστε δική σας κονία. Δώστε μόνο τα τελευταία 1-2 εκ της επικάλυψης με R3, R4. 13. Ο υδροφοβισμός και η βαφή είναι η καλύτερη προστασία της επισκευής. Ακολουθήστε το πρότυπο του ΕΝ 1504. 14. Εαν υπάρχουν χλωριόντα στην μάζα του σκυροδέματος η καθαίρεση ή χρήση γαλβανικής/καθοδικής είναι απαραίτητη. 15. Η φθηνότερη λύση ποτέ δεν θα σας δώσει την απαιτούμενη ζωή. Link to comment Share on other sites More sharing options...
