Ενανθράκωση με διάβρωση
Limit state of water permeability for reinforcement corrosion< 1.3 x 10–13 cm/s Concrete Institute of Australia
Penetron Treated Concrete (28 days old) 21.9 x 10-14 cm/s
  • Απαντήσεις 2,3k
Μία απο τις σοβαρότερες δουλείες που έχω δει.
http://www2.ceegs.ohio-state.edu/~sezen/Publication_docs/Sezen_PhD_thesis.pdf
Αναστολείς διάβρωσης ή κατα το Αγγλικό Modified Corrosion Inhibitors (MCIs)
Corrosion inhibitors. Corrosion-inhibiting admixtures are essentially
designed to improve the performance of good-quality reinforced concrete.
It has been emphasized that the function of such admixtures is
not to “make good concrete out of poor quality concrete.”59 Adherence
to this important principle is important in order to avoid unrealistic
performance expectations for corrosion inhibitors in concrete.
One of the better-known corrosion-inhibitor admixtures used in
attempting to control chloride-induced rebar corrosion is calcium
nitrite, Ca(NO2)2. The mechanism of inhibition involves nitrite ions
competing with chloride ions to react with Fe2+ ions produced at the
anode. Essentially, the nitrite ions limit the formation of unstable
iron chloride complexes and promote the formation of stable compounds
that passivate the rebar surface. The following reactions have
been proposed:
The results of surface analysis of rebar steel exposed to concrete
pore solutions inhibited with calcium nitrite have been entirely consistent
with this proposed mechanism.60 Since nitrite ions compete
with chloride ions to interact with ferrous ions, the ratio of nitrite to
chloride ions is important for adequate corrosion protection.
Εδώ λοιπόν είναι και η βασική δυσκολία που πρέπει να γνωρίζουμε οταν προδιαγράψουμε ένα αναστολέα. Α) το ποσοστό των ενεργών calcium
nitrite, Ca(NO2)2 και β) το πόσο χλωριόντα έχουμε να παλέψουμε. Μια χοντρική εκτίμηση είναι 10 Kgr/m3/ per 1.5Kgr/m3 chlorides.
Με λίγα λόγια για να απλοποιήσω το θέμα με τους Αναστολείς διάβρωσης
οι τιμές των χλωριόντων είναι αμερικάνικες 1 pounds/yard3 = 0.6 κιλα/κυβικό
Μέχρι τα 3.5 κιλά/κυβικό χλωριόντα περίπου στα >200 μέτρα απο την θάλασσα δουλεύουν καλά μειώνοντας την έναρξη. Εαν είμαστε πιο κοντα απο τα 200 μέτρα τότε δεν αλλάζει τίποτα. φωτό 1.
Εαν ξεκινήσει η διάβρωση τότε ενεργοποιούνται σε όλα τα φάσματα και δίνουν βελτίωση. φωτό 2 (μείωση ρυθμού διάβρωσης)
Τώρα ανάλογα την συγκέντρωση αλλα δουλεύουν καλύτερα και άλλα χειρότερα ανάλογα την συγκέντρωση. Αυτό διότι τα ενεργά τους συστατικά ελέγχουν τα παράγωγα της διάβρωσης μειώνοντας αυτά με υψηλούς όγκους (ρηγμάτωση). φωτό 3.
Το 2008 ρίχνω σε 20/25 υδροφοβισμό . Έκτοτε έχει φάει καμιά 200 βροχές. Τα υπόλοιπα στις φωτο.
έπαιζα με ένα νεο προϊόν και μου είχαν στείλει 200ml. Ναι σημειακά για να βλέπω την διαφορά. Είναι 2 κυβικά που περίσσευαν και τα έκανα ράμπα.
1. Τις δυνατότητες του προιόντος με το οποίο ψεκάστηκαν τα 4 κυλινδρικά δείγματα (σκυρόδεμα - χάλυβας B500c) θα τις ¨δούμε " μετά απο δύο μέρες (εκτός θαλάμου διάβρωσης) όταν τα ξαναμετρήσουμε.
2. Το διδακτορικό (PhD Thesis) του Χαλίλι Σεζάν είναι πάρα πολύ καλό, όντως.
Παρότι βέβαια, βρίσκεται σε έναν γνωστό δρόμο που δίνει αποτελέσματα που καιρό τώρα (περίπου) τα αναμένουμε (απο βιβλιογραφία και απο τις απαντώμενες αστοχίες λόγω σεισμού). Ενδιαφέρον τεράστιο θα έχει να επαναληφθεί μία τέτοια εργασία, σε υποστυλώματα (παλαιάς κοπής) με σταδιακή διάβρωση του χάλυβα.
Xάρη ήταν άλλο υλικό είναι το Sikagard 704s.
