pk10gr Δημοσιεύτηκε December 27, 2022 at 10:48 πμ Δημοσιεύτηκε December 27, 2022 at 10:48 πμ split data from one cell to multiple cells google it!
chrispan Δημοσιεύτηκε December 27, 2022 at 11:50 πμ Δημοσιεύτηκε December 27, 2022 at 11:50 πμ Στο cell Α1 = "δοκιμή διαχωρισμού κειμένου με διαφορετικό διαχωριστικό π.χ. - ή / ή οτιδήποτε" εντολή Separator(A1;1) = δοκιμή Separator(A1;2) = διαχωρισμού Separator(A1;2;"-") = - ή / ή οτιδήποτε Σε ένα module γράφουμε τον παρακάτω κώδικα Function Separator(strCell As String, NumWord As Long, Optional Sep As String = " ") As String Dim a As Integer, b As Integer, Kena As Long Dim Start(1 To 15) As Long, Leght(1 To 15) As Long For b = 1 To 15 Start(b) = 1 Leght(b) = 1 Next b strCell = TrimAll(strCell) Kena = CountIn(strCell, Sep) For a = 1 To Kena + 1 If a = 1 Then Start(1) = 0 Leght(1) = InStr(1, strCell, Sep, vbBinaryCompare) Else Start(a) = InStr(Start(a - 1) + 1, strCell, Sep, vbBinaryCompare) If InStr(Start(a) + 1, strCell, Sep, vbBinaryCompare) = 0 Then Leght(a) = Len(strCell) - Start(a) + 1 Else Leght(a) = InStr(Start(a) + 1, strCell, Sep, vbBinaryCompare) - Start(a) End If End If Next a If NumWord = 1 Then Separator = (Left$(strCell, Leght(1))) Else Separator = (Mid$(strCell, Start(NumWord), Leght(NumWord))) End If 'Separator = Leght(NumWord) End Function Function TrimAll(ByVal strInput As String, _ Optional blnRemoveTabs As Boolean = True) As String Const conTowSpace = " " Const conSpace = " " strInput = Trim$(strInput) If blnRemoveTabs Then strInput = Replace(strInput, vbTab, conSpace) End If Do Until InStr(strInput, conTowSpace) = 0 strInput = Replace(strInput, conTowSpace, conSpace) Loop TrimAll = strInput End Function Function CountIn(strText As String, strFind As String, _ Optional lngCompare As VbCompareMethod = vbBinaryCompare) As Long Dim lngCount As Long Dim lngPos As Long If Len(strFind) > 0 Then lngPos = 1 Do lngPos = InStr(lngPos, strText, strFind, lngCompare) If lngPos > 0 Then lngCount = lngCount + 1 lngPos = lngPos + Len(strFind) End If Loop While lngPos > 0 Else lngCount = 0 End If CountIn = lngCount End Function split data from one cell to multiple cells.xlsmFetching info...
Gousgounis Δημοσιεύτηκε December 29, 2022 at 04:35 μμ Δημοσιεύτηκε December 29, 2022 at 04:35 μμ Μπορείς και έμμεσα μέσω μόνο excel να "τραβήξεις" τα νούμερα πχ με τον τύπο =MID(A1;SEARCH("=";A1);SEARCH(",";A1)-SEARCH("=";A1)) σε μία στήλη δίπλα, "τραβάς" το νούμερο ή το κείμενο που βρίσκεται μεταξύ του "=" και του "," δηλαδή το Χ και με το =RIGHT(A1;11) μπορείς να πάρεις το Υ, αρκεί να είναι σταθερά 11 χαρακτήρες (δεν κάθομαι τώρα να σκεφτώ κάτι περισσότερο αυτοματοποιημένο αλλά μπορείς αντί για 11 πχ να βάλεις κάτι καλύτερο χρησιμοποιώντας search για το 2ο "=" και το πλήθος ψηφίων του κελιού) 2
zazeng Δημοσιεύτηκε January 4, 2023 at 03:34 μμ Δημοσιεύτηκε January 4, 2023 at 03:34 μμ To open/libre office έχει την REGEX, αλλά αν δεν κατέ'εις από regular expressions πιο γρήγορα θα το κάνεις με το χέρι (εκτός κ αν έχει όρεξη για λίγο διάβασμα) (προφανώς ούτε εγώ κατέχω, αλλιώς θα στο έλεγα). Άλλη λύση είναι να το κάνεις .csv με το notepad και να το κάνεις import. (To = κάντο replace με , )
