erling Δημοσιεύτηκε Απρίλιος 21 , 2010 Share Δημοσιεύτηκε Απρίλιος 21 , 2010 Βρήκα το παρακάτω στην σελίδα της F-Secure. Εγώ το δοκίμασα και το αντιλαμβάνεται σαν virus αλλά εγώ έχω και το πρόγραμμα της f-secure. Αν θέλει ας το δοκιμάσει κάποιος άλλος στο δικό του anti-virus EICAR Name : EICAR Category: Clean - Not Malware Type: Other Platform: W32 Summary The correct operation of F-Secure Anti-Virus products can be tested with a special test file. This is a dummy file which is detected exactly as if it were a virus. This file is known as the EICAR Standard Anti-Virus Test file. The EICAR test file is also detected by several other antivirus products in a similar manner. Additional Details To create an EICAR test file, use any text editor to create a file with the following single line in it: • X5O!P%@AP[4\PZX54(P^)7CC)7}$EICAR-STANDARD-ANTIVIRUS-TEST-FILE!$H+H* Save the file with any name using a COM extension; for example, EICAR.COM. Make sure you save the file in standard MS-DOS ASCII format. Now you can use this file to demonstrate what occurs when a virus is detected. Naturally, the file is not a virus. When executed, EICAR.COM will display the text "EICAR-STANDARD-ANTIVIRUS-TEST-FILE!" and exit. EICAR is the European Institute of Computer Anti-virus Research, reachable at http://www.eicar.org. Link to comment Share on other sites More sharing options...
