alexandermech Δημοσιεύτηκε December 6, 2010 at 07:25 πμ Δημοσιεύτηκε December 6, 2010 at 07:25 πμ ΓΝΩΡΙΖΕΙ ΚΑΠΟΙΟΣ ΠΟΙΑ ΤΑ ΚΑΤΑΛΛΗΛΑ ΠΥΡΟΣΒΕΣΤΙΚΑ ΜΕΣΑ ΓΙΑ ΒΑΡΕΛΙΑ ΜΕ ΜΕΙΓΜΑ ΙΣΟΠΡΟΠΑΝΟΛΗΣ; ΥΠΑΡΧΟΥΝ ΑΠΑΙΤΗΣΕΙΣ ΓΙΑ ΑΛΛΑ ΜΕΤΡΑ ΠΥΡΟΠΡΟΣΤΑΣΙΑΣ;
CostasV Δημοσιεύτηκε December 6, 2010 at 08:10 πμ Δημοσιεύτηκε December 6, 2010 at 08:10 πμ Fire Fighting Media and Instructions: Flammable liquid, soluble or dispersed in water. SMALL FIRE: Use DRY chemical powder. LARGE FIRE: Use alcohol foam, water spray or fog. Πηγή: http://www.sciencelab.com/msds.php?msdsId=9924412 ------------------------------------------------------ Fire Extinguishing Media: Water spray, dry chemical, alcohol foam, or carbon dioxide. Water spray may be used to keep fire exposed containers cool, dilute spills to nonflammable mixtures, protect personnel attempting to stop leak and disperse vapors. Special Information: In the event of a fire, wear full protective clothing and NIOSH-approved self-contained breathing apparatus with full facepiece operated in the pressure demand or other positive pressure mode. Πηγή: http://www.jtbaker.com/msds/englishhtml/i8840.htm ------------------------------------------------------------------------------ EXTINGUISHING MEDIA: NFPA Class B extinguishers (carbon Dioxide or foam) for Class I B liqid fires. SPECIAL FIRE FIGHTING PROCEDURES: Water spray may be ineffective on fire but can protect fire-fighters & cool closed containers. Use fog nozzles if water is used. Do not enter confined fire-space without full bunker gear. (Helmet with face shield, bunker coats, gloves, & rubber boots). Use NIOSH approved positive-pressure self-contained breathing apparatus. Πηγή: http://transdesign.com/MSDS/La%20Palm/La%20Palm%20Alcohol%2070%20MSDS.pdf ----------------------------------------------------------------------------------------------------- Καλύτερα όμως να δεις το MSDS που συνοδεύει τις συσκευασίες της ισοπροπανόλης όπως αυτό (το MSDS) έρχεται από τον προμηθευτή σας. ΥΓ. Μην γράφεις με κεφαλαία γράμματα και αν μπορείς, διόρθωσέ τα σε μικρά. Καλώς ήρθες στο φόρουμ!
Μαρκετάκης Ιωάννης Δημοσιεύτηκε December 11, 2010 at 08:35 μμ Δημοσιεύτηκε December 11, 2010 at 08:35 μμ Η "Ισοπροπανόλη" είναι η "Ισοπροπυλική αλκοόλη" δηλαδή μία αλκοόλη (ΟΗ) με τρεις άνθρακες (PROP), αλλά στην αλυσίδα ό ένας είναι σε διακλάδωση (ISO). Χρησιμοποιείται σαν καθαριστική ουσία χημικών κυρίως και δεν διαφέρει σε πολύ από την αιθυλική αλκοόλη όσον αφορα την κατάσβέσή της. Dry Powder, CO2, ή Αφρός alcohol resistant. Όχι νερό (γιατί επιπλέει και παρασείρεται) εκτός αν πρόκειται για ομίχλη.
