cls Δημοσιεύτηκε February 7, 2009 at 04:53 μμ Δημοσιεύτηκε February 7, 2009 at 04:53 μμ Autodesk Robot™ Structural Analysis Professional 2010 Autodesk Robot Structural Analysis Professional 2010 software provides a scalable, countryspecific analysis solution for the structural engineer to help analyze many types of structures, including buildings, bridges, civil and specialty structures. Autodesk Robot Structural Analysis Professional calculates a wide variety of structures with a comprehensive collection of design codes, delivering results in minutes, not hours. This structural engineering software is versatile enough for simple structural frame analysis or complex finite element analysis and offers smooth interoperability with Autodesk companion products as well as an open application programming interface (API). What’s New Enhanced Modeling and Collaboration Capabilities Integrate more efficiently between Autodesk Robot Structural Analysis Professional and Autodesk Revit Structure. New approach to building structures with the added ability to create objects such as beams columns, and walls in lieu of bars and panels. Import DXF™/DWG files as a drawing background, making it possible to define 3D structural models on the basis of architectural plans and elevations. More Improved Design and Analysis Experience New harmonic and damping analysis parameters have been added, as well as a more improved and amended footfall analysis. New national reinforcement, load combination and steel codes have been implemented into the application, as well as regional codes for Sweden, Australia and Italy. Greater Usability Enhanced creation of load distributions allows users to better analyze load distribution to beams, columns and walls. Work more easily with improved, user-friendly steel connections definitions, with updated dialog boxes. Work more easily with Eurocode safety factors with a comprehensive dialog box that contains all Eurocodes available in the program and an additional user-defined set of parameters. μολις πηραμε το 2009 , βγαζουνε το 2010. Κατα τον Απριλιο μαλλον. Βλεπω να θελουν αλλα 1000€ για την αναβαθμιση ( η το subscription ). Μαλλον σ'αυτη την εκδοση θα ειναι και τα ελληνικα...
ppetros Δημοσιεύτηκε February 7, 2009 at 06:15 μμ Δημοσιεύτηκε February 7, 2009 at 06:15 μμ Οποιος έχει σημειώσεις ή απαντήσεις σε ερωτήσεις που έκανε παλιότερα για την χρήση του προγράμματος μπορεί αν θέλει να τα ανεβάσει κάπου (π.χ. rapidshare ....) για να μπορέσουμε όλοι να βοηθηθούμε. Ευχαριστώ....
ppetros Δημοσιεύτηκε February 12, 2009 at 05:13 μμ Δημοσιεύτηκε February 12, 2009 at 05:13 μμ Δεν τα έχει κανείς σε pdf? Νομίζω έδινε και κάποιες σημειώσεις όταν παρακολουθούσες σεμινάρια.
paktomenos Δημοσιεύτηκε February 12, 2009 at 05:21 μμ Δημοσιεύτηκε February 12, 2009 at 05:21 μμ http://rapidshare.com/files/133503067/_________________manual_ROBOT.zip τα μόνα που έχω και ξέρω...
spy1551 Δημοσιεύτηκε February 12, 2009 at 06:30 μμ Δημοσιεύτηκε February 12, 2009 at 06:30 μμ ppetros said: Δεν τα έχει κανείς σε pdf? Νομίζω έδινε και κάποιες σημειώσεις όταν παρακολουθούσες σεμινάρια. Πέτρο σου έστειλα κάποια pdf στα Ελληνικά.Πιθανόν ο Μαραβέας να έχει και άλλα.Αυτά μου τα είχε στείλει κατόπιν τηλεφωνικής ερώτησης. Στο dvd εγκατάστασης έχει κάποια manual στα Αγγλικά. Tώρα είδα το αρχείο που ανέβασε o paktomenos.Έχει περισσότερα από αυτά που έχω. Σου έστειλα και τα παλιά manual στα Αγγλικά.
ppetros Δημοσιεύτηκε February 12, 2009 at 07:20 μμ Δημοσιεύτηκε February 12, 2009 at 07:20 μμ Να είστε καλά παίδες (paktomenos+spy1551). Εχει να πέσει διάβασμα....
Chihor Δημοσιεύτηκε February 13, 2009 at 07:34 πμ Δημοσιεύτηκε February 13, 2009 at 07:34 πμ Στην ιστοσελίδα για το robot υποτίθεται ότι έχει demo έκδοση του προγράμματος για την απόκτηση της οποίας απαιτείται κωδικός. Έχω στείλει μέχρι στιγμής δύο mail ζητώντας να μου στείλουν κωδικό και έχω φάει άκυρο και τις δύο φορές. Έχει κατεβάσει κανένας την έκδοση; Ισχύει αυτό που γράφουν ή είναι κάτι που έχει ξεχαστεί στο site τους;
ilias Δημοσιεύτηκε February 13, 2009 at 07:41 πμ Δημοσιεύτηκε February 13, 2009 at 07:41 πμ Και εγώ τα ίδια! Τρεις φορές έστειλα e-mail.
Chihor Δημοσιεύτηκε February 13, 2009 at 07:49 πμ Δημοσιεύτηκε February 13, 2009 at 07:49 πμ Κατάλαβα.... Η πολιτική προώθησης του προϊόντος κάπου πάσχει.
Barracuda Δημοσιεύτηκε February 13, 2009 at 07:53 πμ Δημοσιεύτηκε February 13, 2009 at 07:53 πμ Μπορειτε να το κατεβασετε απο την autodesk, http://usa.autodesk.com/adsk/servlet/mform?siteID=123112&id=12031356 Συμπληρωνεις μονο την φορμα.
