ZaXoYs Δημοσιεύτηκε November 11, 2009 at 10:10 μμ Δημοσιεύτηκε November 11, 2009 at 10:10 μμ Αντιγράφω από www.modelica.org Modelica is a non-proprietary, object-oriented, equation based language to conveniently model complex physical systems containing, e.g., mechanical, electrical, electronic, hydraulic, thermal, control, electric power or process-oriented subcomponents. See also, overview in pdf, ppt format and Modelica Language Specification 3.1. Modelica Libraries with a large set of models are available (overview, details and download). Especially, the open source Modelica Standard Library contains about 920 model components and 620 functions from many domains. Modelica Simulation Environments are available commercially and free of charge, such as CATIA Systems, Dymola, LMS Imagine.Lab AMESim, JModelica.org, MapleSim, MathModelica, OpenModelica, SCICOS, SimulationX. Modelica models can be imported conveniently into Simulink using export features of Dymola, MapleSim and SimulationX Φαίνεται ιδιαίτερα ενδιαφέρον , μόλις βρω χρόνο (που δεν αναμένεται άμεσα όμως) θα τσεκάρω την βιβλιοθήκη WasteWater Free library for modelling and simulation of waste water treatment plants. και θα γράψω εντυπώσεις
iovo Δημοσιεύτηκε November 12, 2009 at 07:17 πμ Δημοσιεύτηκε November 12, 2009 at 07:17 πμ Πολύ ενδιαφέρον Zaxoys ευχαριστούμε.
